m50 MAF MOUNTING MADNESS
Jamie8GTi
Post Mon Feb 03, 2014 6:27 pm
Okay so I cut all my air box mounts off out of my bay as I'm going for a cone filter straight on the MAF of my M50 B25
Question is will it mechanically make any difference which way up the MAF is mounted? I want to twist it to the right 90 degrees to hide the wiring and plug..
As I'm making a new mount this will have to be made to suite which ever way up the MAF is turned so before I make it Could anyone confirm it will still function properly??
heres oem..
heres suggested..
Just randomly came into my head and thought it best to check, as the engine won't be fired up until the bay is sprayed.
Post Mon Feb 03, 2014 6:35 pm
Normally this way
Jamie8GTi
Post Mon Feb 03, 2014 6:40 pm
Do you know if it will still work on its side? I've had 1.8t's with MAF's upside down before but just wanted to check.. its purely aesthetics in mind
Post Mon Feb 03, 2014 6:50 pm
To me, it would look wrong upside down, but it probably would work perfectly ok
JF008
Post Thu Feb 06, 2014 3:54 pm
You may find that an after market maf can cause you cold start fluctuating revs, took me a while to find out the culprit on mine just a heads up :D
Jamie8GTi
Post Thu Feb 06, 2014 6:22 pm
Its a genuine bosch Maf! the problem I had was that I had absolutely no way of securing it or the air filter! as id cut off all original mounts for the air box! its all sorted now :) thanks
Post Thu Feb 06, 2014 8:46 pm
As you have no ABS pump down there why not just fit the E36 airbox?
Jamie8GTi
Post Fri Feb 07, 2014 10:49 am
Haha being 21 I Prefer boy racer cone filters! Won't really rag it through puddles after all this so shouldn't ever be a problem :)
ross_jsy
Post Fri Feb 07, 2014 11:08 am
It's just going to be sucking in warm air from the engine bay though. BMW air boxes are very well designed.
