Crank sprigot bearing
jimmymig
Post Thu Jan 30, 2014 8:28 am
Do I use e30 sprigot bearing with m52 and e30 gearbox cheers jim
Post Thu Jan 30, 2014 9:49 am
Basically, yes, but check that the inside diameter of the bearing matches the size of the gearbox spigot.
jimmymig
Post Fri Jan 31, 2014 12:48 am
Thank Brian couldn't remember what I fitted to my last engine
Post Fri Jan 31, 2014 10:15 am
It's not the engine type that determines things. A M50 or M52 spigot bearing will fit a M10/20/40/42 engine and vice versa.
The range of gearboxes likely to be considered have a 12mm or a 15mm diameter input shaft spigot, so the bearing needs to be chosen to match this.
