Crank sprigot bearing
jimmymig
Do I use e30 sprigot bearing with m52 and e30 gearbox cheers jim
Basically, yes, but check that the inside diameter of the bearing matches the size of the gearbox spigot.
jimmymig
Thank Brian couldn't remember what I fitted to my last engine
It's not the engine type that determines things. A M50 or M52 spigot bearing will fit a M10/20/40/42 engine and vice versa.
The range of gearboxes likely to be considered have a 12mm or a 15mm diameter input shaft spigot, so the bearing needs to be chosen to match this.
