Does anyone have any experience using sump plugs as in the link below?
http://www.ebay.co.uk/itm/Magnetic-Sump ... 58aa99d08c
Some numpty has over tighten the plug on my M20 sump and now its forever spinning.
I’m thinking of tapping a bigger hole on the sump and using one of these magnetic plugs?
Does anyone know the current OEM sump plug size?
Magnetic Sump plug
beemerbird
I think it's an M12, but with a relatively small head, so requiring a 17mm spanner to tighten.
Yes they are M12, you can buy a repair kit/inserts to retain the original plug size
SilverShadow
- Hartge Crew
Thanks! Any experience with the magnetic plugs?
I'll be going one size over when re-threading to M14?
SilverShadow
- Hartge Crew
Any recommendations?DanThe wrote:Yes they are M12, you can buy a repair kit/inserts to retain the original plug size
Im sure you can buy them on ebay, doesnt need to be the best quality as its only a sump plug thread
