M20 auto transmission in m40
Strueth! It only took you 7 years to make your first post!!
Welcome to the Zone!
- Brianmoooore
Don't forget that an auto. box has a separate bell housing, so although the complete assembly won't fit, if you're replacing a faulty gearbox with a good one, it might well be possible to swap over the bell housing.pacerpete wrote:Quick answer = No
The main gearbox casing is identical.
Brianmoooore wrote:Don't forget that an auto. box has a separate bell housing, so although the complete assembly won't fit, if you're replacing a faulty gearbox with a good one, it might well be possible to swap over the bell housing.pacerpete wrote:Quick answer = No
Any other thoughts on this ? One says no other say maybe?
