IGNITION REMOVAL
FMH
any instructions how to remove the ignition barrel?
Turn key to first 'on' position, insert rod (small alen key is ideal) into the small hole on the front face, and withdraw the barrel from its housing.
Sounds easy, but it will probably keep you amused for several minutes. Once you've done it, you will be able to refit it and remove it again in seconds, or remove one from another E30 in an equally short time.
FMH
Thanks Mr.MooreBrianmoooore wrote:Turn key to first 'on' position, insert rod (small alen key is ideal) into the small hole on the front face, and withdraw the barrel from its housing.
Grrrmachine
- E30 Zone Wiki / Team Member
