block painting...to last
tim_s
Post Fri Dec 23, 2005 5:36 pm
hi all, i've got an m42 block to paint, and I'm wondering how i can do it without what usually happens to me when i paint engines - i.e. a few thousand miles down the road it peals off to be left with the usual rusty iron. i always use proper engine enamel and have prepped the block by wire brush, gunk + pressure wash then acid/kurust. but nothing ever seems to work. what am i doing wrong? tempted to hammerite it i must admit.
cheers
tim
2.1 318is, MS, LPG. 200bhp, 175ft/lbs GONE!
Boxster, e46 m3, e36 sport touring and alpina B3 3.0
eko
Old timer
Post Fri Dec 23, 2005 5:45 pm
if it helps,in the past ive used Tractor paint from a local farm supplier/store called Mole Valley Farmers.
Gives a really good finish,even if your a bit rough with it like i was,comes in loads of different colours,green,yellow,blue,red etc and lasts pretty well too.
Half litre tin was about Ԛ£4 + VAT and lasts for ages!
tim_s
Post Fri Dec 23, 2005 5:49 pm
lol i've heard of mole valley farmers... my granny's in devon. maybe i'll give some of that a crack!
i'm thinking of really working on the prep this time, getting a real nice surface and giving it a once over in etch primer, even though the engine enamel i've used in the past says to use it straight onto the block.
