Door plug housing
M3Jim
Post Tue Nov 05, 2013 4:36 pm
I need to replace the plastic plug housing on the doors, because at some point the tabs have been broken and the rubber seal doesn't clip on anymore. Is this easy to replace or does it mean all the wiring has to be removed from the plug?
d1mkaz
Post Wed Nov 06, 2013 10:50 am
The plug cost around £5 for both (it's 2 parts) from Cotswoldbmw, to take the pins out you'll need a special tool, that you can't buy from BMW :) if you are not a garage or smth., but you can get it from eBay. I used this: http://www.ebay.co.uk/itm/Durite-0-703- ... _392wt_934
not the best tool I guess but it did a trick.
Post Wed Nov 06, 2013 1:20 pm
You can also buy the pins from BMW, you will probably need to replace a few
bigbird76
Post Wed Nov 06, 2013 9:54 pm
I think the pins cost a fair bit as you need quite a few.
From memory I think RS do the same pins and will be cheaper just for you to know if you go down that road.
Leigh
M3Jim
Post Thu Nov 28, 2013 4:20 pm
Thanks guys!
Leigh who are RS?
Did you sort your exhaust out? Haven't been able to see as S14.net is still down!!!!
hennared323i
Post Thu Nov 28, 2013 4:22 pm
M3Jim wrote:Thanks guys!
Leigh who are RS?
RS Components:
http://uk.rs-online.com/web/
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Nov 28, 2013 4:43 pm
All the part numbers and the wiring diagrams for this job are in the Wiki:
http://www.e30zone.net/e30zonewiki/index.php/C404#Parts
