putting together the clutch and flywheel in a m52 swap HELP!
breakermart
Post Mon Oct 14, 2013 10:40 pm
ok iv got
M52B28 engine from a 5 series auto..
Manual gearbox from a 2.8 E36..
iv just bought a flywheel from a M20..
matching starter motor on its way..
do I have to buy a clutch that is for the m52b28 or one that's for a m20b25?
and wich spigot bearing do I use?
finaly, is there anything else I need to do. iv heard about spacers and also something about removing some metal from the flywheel.... im a bit confused!!! if somebody could explain whats needed like im 5 years old lol then that would be great. :o:
maggspower
Turbo Farmer Tractor Driver
Post Mon Oct 14, 2013 10:44 pm
Clutch needs to be the m20b25 item. Sachs ones are cheap at carparts4less.
You will need, m52b28 spigot bearing, although I think they are all the same.
breakermart
Post Mon Oct 14, 2013 10:46 pm
ok that answers that perfectly thankyou
Post Mon Oct 14, 2013 10:49 pm
If its a ZF E36 box you will need a 15mm spigot bearing, the spacer/spreader plate goes between the flywheel and the bolts, to spread the load from the bolts.
The M20 flywheel will need to be machined/lightened to fit onto the M52 engine
breakermart
Post Mon Oct 14, 2013 10:57 pm
how much we talking about being machined off the flywheel then?
also spacer/spreader plate? im unsure what this is.
cheers :D
by the way danthe how much for the adaptor to make my loom fit the e30?
Post Mon Oct 14, 2013 11:01 pm
Dont do adaptors mate, just do loom conversions so the loom fits the car in the same way an original E30 engine loom would
breakermart
Post Mon Oct 14, 2013 11:05 pm
ok il keep that in mind mate cheers
AndyZippy
Post Tue Oct 15, 2013 9:56 am
Can definately recommend Dan's loom, simple as simple gets to fit :thumb:
