e30 330 m54 conversion info wanted please
A NEED A REALLY SWEET LUMP IN MA WEE CAR AS AM SICK DOIN THE TAPPETS AN KINDA FANCY A 24V CONVERSION BUT ALL IN ALL A WOULD BE MORE THAN HAPPY WITH A A1 M20 RECON/REFURB?? MINES HAS A FEW MILE ON THE ENGINE AM USING AN THE TOP END HAS QUITE A BIT AE WEAR IN ER  SO WHAT YOU'S RECKON??
 SO WHAT YOU'S RECKON??- Kos
- Contact:
I still have the urge to one day build a hot m20,
2.6 over bore with high comp low friction pistons
knife edge lightened crank and light flywheel
big valve head and spikey cam
Large TB (maybe ITB's) and a BTB manifold
Run it on a proper management system
It will probably cost the same as dropping in an s50 but I think it would be more fun with a tunes m20
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
so no info about m54 swap?
here is all you need for electrics
http://www.r3vlimited.com/board/showthread.php?t=275468
what about engine mounts,driveshaft,gearbox,can i use gearboz from e46 330ci?
engine mounts from e36 m50/52,oil pan from e34 m50.
