i seem to remember that there is an engine mount from another bmw model thats stronger in its design than the standard mount. its for a rally car that im building so im not over worried about any vibrations or extra noise.
does anybody know what model they are from or a part number would be even better. cheers
m42 engine mount upgrades
age
- Formerly twist316
E28 m5 cylindrical mounts.
M40 rightness if you can get to 6000rpm noone can hear your tappets
rix313
There are a couple of options. M10 ones work too by all accounts. I started a thread on M42 club about this and M10 and the E28 mounts seemed to be the favourites.
I have some Vorshlag ones but the studs on them are too short so I need to have a play around with them.
AdamGardner
cheers guys been looking at part numbers on real oem, i want to get these changed as i have had few standard ones fail through big landings.
NoTurbo
Hi Pal,
What did you go with in the end?
AdamGardner
used e34 m50 engine mounts, as used in the german 318is rally championship. the cars not running as yet so I cant comment if they would make any excessive noise in a road car.
