I changed the diff oil about 2 months ago and since then it's been slowly pissing from there. And by the way, I haven't overfilled it, as when you take out the filler plug, no oil comes out.
Went down to BMW the other day and bought a new plug with a new washer, put them on today and it's STILL leaking?
Some pics for you:
The silver ring you can see around the top plug is the original washer that was on the car, before I changed oil. I wouldn't think it's genuine BMW, but you can clearly see it's a lot wider...
The original plugs are 10mm, but the new ones are 14mm, although they fit perfectly. Also new ones got a green rubber ring on them, but originals don't have anything...
I've heard people put RTV on the threads, so is that my only option, or I'm doing something wrong?
P.S. Drain plug is ok.
