Ledas Fitted
JamesM3
Post Mon Dec 12, 2005 1:06 pm
Hi All,
Just got my car back from having Leda Coilovers fitted. Great improvement in cornering and weight transfer, although they are fairly stiff now !
Here are a few pics...
Post Mon Dec 12, 2005 1:08 pm
they look a bit horny!! :twisted:
What brakes are you running?
CorollaRWD
Post Mon Dec 12, 2005 1:24 pm
Wow, what adjustments do the piggy back have high low speed compression or rebound?
Karan
Post Mon Dec 12, 2005 1:40 pm
i waqnt these for my driftcar.. how much were they?
cheers
Karan
JamesM3
Post Mon Dec 12, 2005 2:38 pm
The Brakes are Tarox G88 disks with Ferrodo DS2500 pads.
Front shocks are fully adjustable oil filled, with 475 lbs main springs with helper springs
Rear shocks are remote canister gas pressurised fully adjustable, with 225 lb main springs and helper springs again.
Shocks and springs were a little short of 2K fitted :( but this thing handles just a little bit now :D
kam-325i
Post Mon Dec 12, 2005 2:47 pm
Helper springs ?
Geeman
Post Mon Dec 12, 2005 2:58 pm
So they are 'real' coilovers on the rears now too...?
That means that the whole of the rear suspension is now sat on the two lower shock mounts, rather than the spring plates... have you had to toughen up the shock mounts at all...?
Just curious... as my 'pretend' FK coilovers were still using the spring plates on the rear, with an adjuster fitted.
Giles.
JamesM3
Post Mon Dec 12, 2005 3:08 pm
Yes, they are real coilovers at the back too, I am assured that the shock mounts at the rear are way more than strong enough to take the springs and shocks together !
The helper springs are far softer than the main springs and are used to help absorbe some of the banging and crashing that you would get with firm springs and rose joints.
Geeman
Post Mon Dec 12, 2005 3:16 pm
I thought the 'helper' springs were there to make sure the 'real' springs don't dislocate when the body is raised as the 'real' springs haven't got any play in them as they're so stiff... as when the weight is back down on the wheels again, the helper springs are completely squashed.
They look cool though... but Ԛ£2k is a lot of money to splash out with... I'm glad they're preforming well though fella!
Giles.
JamesM3
Post Mon Dec 12, 2005 3:23 pm
it was a lot to spend, but a recent change of job has left me a little more flush. A half cage and some decent seats is nect on the list.
As Geeman says I'm pretty sure that is another reason to have the helper springs fitted.
Geeman
Post Mon Dec 12, 2005 3:25 pm
Coolio.
Would like to have Ledas on my next project (whenever that is)
Are they okay for normal daily driving, or are they a pure race track set-up?
sideways_kyeway
Post Mon Dec 12, 2005 3:29 pm
Wicked looking suspension set up.... :D
Wish i had that kinda green to blow on a suspension..... :(
Seriously though, is it worth the full Ԛ£2k...there are cheaper set ups from companies like KW that would be worth a look.... :rasta:
WANTED: 24V E30... :)
JamesM3
Post Mon Dec 12, 2005 3:34 pm
to be honest, I am 99% sure that they will be fine for daily driving.
They are firm, there is no question about that, but I guess it depends what you want. I have only driven the car about 25 miles since having them fitted. About 5 of these were down country lanes near the Leda factory - i must say this was quite unpleasant !
Apart from that it was all on 'normal' roads which was fine - fantastic round roundabouts !
Put it this way - if you were a girl a sports Bra would be advisable.
Its only the driver that needs to improve now :roll:
Martinaston
Post Mon Dec 12, 2005 5:26 pm
That pipe looks like it will sit a bit close to the chassie when it's back on it's wheels :?
There is NO nucleus.
glenn
Engine Transplant Services
Post Mon Dec 12, 2005 5:56 pm
well done james, glad your pleased with them.
the best handling car i ever went in had leda coil-overs fitted. 8)
dlatch33
Post Mon Dec 12, 2005 11:34 pm
think Gaz shocks do similar kit and much cheaper :wink:
(for those that don't know Gaz is owned and run by one of the original founders of Leda)
Old Skool member
Official ford fan
Sal is ghey :wink:
M5pilot
Post Tue Dec 13, 2005 12:35 am
Nice one dude! Money well spent by the looks of it.
Ignore dltach and his Gaz comment, he has a bad habbit of trying to wind people up. Goes without saying really, you would ignore someone who thinks Fords are built tough.....LOL.... :cry:
