Ews wiring?
fearlessphil
Sun Jul 07, 2013 10:49 pm
i bought an s50 conversion package it was in a running car so i know it works im just a bit puzzled how it all goes together?
this is what ive got
and this is where i think it goes
What im unsure of is do i splice them in or do i cut the wires solder them in and if so which side of the plug
also im guessing the brown wire with the washer connector in the earth?
jmc330i
Sun Jul 07, 2013 11:49 pm
I've got the wiring diags I used for my S50 conversion somewhere. It really isn't hard to wire up.
I'll dig them out, but it might not be for a few days.
James
'91 325i Sport
'93 318i touring 16v
fearlessphil
Sun Jul 07, 2013 11:51 pm
jmc330i wrote:I've got the wiring diags I used for my S50 conversion somewhere. It really isn't hard to wire up.
cheers dude much appreciated!
jmc330i
Mon Jul 08, 2013 12:05 am
No worries 8)
From memory, its about 6 or 7 wires, plus a couple if you want to kill the starter as well ignition.
Did you buy the conversion from Furbster on here?
James
'91 325i Sport
fearlessphil
Mon Jul 08, 2013 12:14 am
yeah, is there a way to do away with it all together?
jmc330i
Mon Jul 08, 2013 12:41 am
I thought I recognised that EWS wiring - that's my old conversion! :D
The only wires you need to connect are the free wires you have - the earth, the two wires that have been labeled (not by me) and the 3 wires from the yellow plug.
The rest that are taped up in a circle are not needed. Some is for the starter inhibitor circuit which I chose not to use, the rest is for circuits not present in the E30.
You can get EWS deleted, but when I enquired it about getting it done (in 2005 ish), there was an issue with that age ECU as its a 3.0ltr with EWS. That's why I kept the EWS, plus the added security is a bonus.
Things have probably moved on since I looked into it, so its probably possible on that ECU now. There is a member on here who can delete EWS, but I can't remember who - it's says in his sig whoever it is.
James
'91 325i Sport
Mon Jul 08, 2013 2:21 pm
I can get rid of the EWS on the B30 quite cheap if needed 8)
jmc330i
Mon Jul 08, 2013 6:54 pm
I knew there was someone who could do it on here :) So there shouldn't be any problems nowadays then?
Although tbh, all the kit is there and it's only a few wires and job done.
James
'91 325i Sport
