Engine Wont Start 318i
OakieBoi
After fitting lowering springs and driving out of the garage Ive hit a metal pole, and broken the engine mounts, now Ive snapped a black bosch wire, and Im not sure where it connects to, the ignition all turns on and the car will not start if anybody coudl help would be great thanks
Grrrmachine
- E30 Zone Wiki / Team Member
That's karma for you
Do you have spark and fuel? And what makes the wire a "Bosch" one?
Billwill
Is this an M40 318i?
Where is this connector located...a picture would help a lot.
Probably the crank sensor which sits below the engine up front.
If you lower a M40 E30 you definitely need a good strong metal sump guard fitted.
