Bosch to BMW part numbers?
Andy325i
Post Mon Jun 03, 2013 10:07 pm
I have a pair of brand new oxygen sensors that came with a breaker (E34 530i V8 1996) The Bosch part number is 0 258 003 231.
How do I cross reference this to a BMW part number so I can find out what other possible models they fit?
Many thanx
Andy
Post Mon Jun 03, 2013 11:05 pm
If they are the ones for the car you have, then just the 530 and 540 : http://bmwfans.info/parts/catalog/11781742023/ although it's likely just to be a difference in cable length between these and many others.
Andy325i
Post Tue Jun 04, 2013 12:11 am
Thankyou Brian :)
Using that Part number, realoem gives it for an E36 M3 (Europe) as well
http://www.realoem.com/bmw/partxref.do? ... showeur=on
Many thanks :)
jmc330i
Post Tue Jun 04, 2013 6:08 am
Andy325i wrote:Thankyou Brian :)
Many thanks :)
Only for one of the sensors Andy, from memory for the left cat and its on the 3.0 M3 only. The right hand sensor has a longer wire and the Evo uses sensors with longer wiring, although as Brian says, the sensors themselves are probably the same... I used two of the 'left' sensors listed above for my S50, but the plug/sockets are sided so you can't plug a left into the right and vice versa - I modified the plug to fit as the wire colours are all the same.
James
'91 325i Sport
'93 318i touring 16v
Andy325i
Post Tue Jun 11, 2013 1:30 pm
Just seen this, thankyou James :)
