I have a pair of brand new oxygen sensors that came with a breaker (E34 530i V8 1996) The Bosch part number is 0 258 003 231.
How do I cross reference this to a BMW part number so I can find out what other possible models they fit?
Many thanx
Andy
Bosch to BMW part numbers?
Andy325i
If they are the ones for the car you have, then just the 530 and 540 : http://bmwfans.info/parts/catalog/11781742023/ although it's likely just to be a difference in cable length between these and many others.
Andy325i
Thankyou Brian
Using that Part number, realoem gives it for an E36 M3 (Europe) as well
http://www.realoem.com/bmw/partxref.do? ... showeur=on
Many thanks
Many thanks
jmc330i
Only for one of the sensors Andy, from memory for the left cat and its on the 3.0 M3 only. The right hand sensor has a longer wire and the Evo uses sensors with longer wiring, although as Brian says, the sensors themselves are probably the same... I used two of the 'left' sensors listed above for my S50, but the plug/sockets are sided so you can't plug a left into the right and vice versa - I modified the plug to fit as the wire colours are all the same.Andy325i wrote:Thankyou Brian![]()
Many thanks
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Andy325i
Just seen this, thankyou James
