Boot Lock HELP!!!
Mo13
Post Sat May 25, 2013 4:52 pm
My boot wont open on my cab....! any way I can get into it? removed the rear bench but cant see any access!
Thanks,
Mo
Mo13
Post Sat May 25, 2013 7:08 pm
Lol it was forking fine until today, the key turns sounds like its unlocked but when I push it in nothing happens!
Post Sat May 25, 2013 9:17 pm
I had a faulty boot lock on my first E30 - you used to be able to get replacements from ECP - buy a new lock first then stick a large screwdriver in it and twat it with a hammer - it will pop the boot job jobbed.
Mo13
Post Sun May 26, 2013 12:23 am
I really doubt the rubber deal will make it this hard I've been yanking it all evening!
Ok from horizontal if I turn 90 degrees to the left (anticlockwise) the push button doesn't go in if I do the opposite, clockwise from horizontal the button goes in and out but the boot lid does not open. So my question is wich way does it lock? Lol
Post Sun May 26, 2013 6:39 am
With the key slot horizontal that should be unlocked, with the key slot vertical that is locked.
If the key turns it sounds like something connected to the lock has come adrift rather than the lock itself being knackered.
I'm sure I've read on here before that there is a way you can pop the boot lock through the rear number plate lamps but its very fiddly.
Failing that you will just need to break the lock as per my previous description :(
Mo13
Post Sun May 26, 2013 8:06 pm
The boot lock has to be horizontal for the key to come out... When I put the key in I can either go anticlockwise or clockwise not sure wich way is unlock.
Any idea where the write up is to access via the number plate lights?
Anyone else got any ideas or is replacement and brute force my only option?
Mo13
Post Sun May 26, 2013 8:20 pm
diable wrote:
:lol:
Mo13
Post Sun Jun 02, 2013 12:38 am
diable wrote:WD40 and keep trying until you give up.
Drenched it and fiddled around for a bit left it for a while and it opened at the second attempt :D happy days
Post Sun Jun 02, 2013 10:11 am
Now service it!
Mo13
Post Sun Jun 02, 2013 10:14 am
Service it........???
Post Sun Jun 02, 2013 10:30 am
Dismantle the lock, clean, lubricate and put back together.
Or it'll likely happen again when the WD40 dries out.
Post Sun Jun 02, 2013 1:47 pm
For the actual lock barrel, yes. Graphite powder is ideal (file down a pencil).
I don't think you can strip down the barrel easily, so take it off, wedge the shutter open, flush it out with WD40, holding it vertically, face down, dry it out, then hold it face up and drop the graphite powder in.
Rest of the lock, clean and ideally a bit of white grease.
Mo13
Post Mon Jun 03, 2013 12:02 pm
Thanks Brian I shall do that.
