Tech 2 steering wheel removal
Podge72
Post Tue May 21, 2013 7:35 pm
How do you remove a Tech 2 steering wheel?
Removed BMW badge from centre expecting to see access to nut to remove but apparently not.
Cheers as usual for advice.
polsta
Post Tue May 21, 2013 8:09 pm
you remove the whole center cover panel it just pulls offf..
Quaser
Post Tue May 21, 2013 8:29 pm
undo the nut until its almost off, put the key in the ignition and remove to take off the steering lock, and pull!
once its loose on the column, you can finish removing the nut :)
bigbird76
Post Wed May 22, 2013 9:54 pm
Quaser wrote:undo the nut until its almost off, put the key in the ignition and remove to take off the steering lock, and pull!
If you don't you might suffer a broken nose :eek: :eek: :eek:
Podge72
Post Thu May 23, 2013 7:35 am
Thanks. One last thing... is the retaining nut is a 22mm?
Post Thu May 23, 2013 9:33 am
Yes.
Podge72
Post Thu May 23, 2013 9:40 am
Thanks guys. Much appreciated.
Podge72
Post Tue May 28, 2013 11:18 am
OK...old wheel off, new wheel on...only problem is horn now not working.
The old tech 2 had two wires brown (presumably earth) and black. New steering boss only has one wire (black) so have connected this to + terminal (i.e same as tech 2 connection) and nothing. Have tried the other terminal too.
I did initally tighten new steering wheel/boss which made the horn go off constantly so slackened off slightly which made it stop, if that has any bearing on anything.
