uprating e30 m3 suspension....
DasChin
Sat May 04, 2013 10:05 am
anyone run the Bilstein B8 sports kit?
they look good and been offered a set to try out. currently m3 is on std shocks and lowered springs. feels a bit floaty.
thanks, DC
ajay
Sat May 04, 2013 10:36 am
Im using B8 dampers with a H&R spring kit and think there great, no floaty business: quite firm but not harsh. Would be my first choice if i was in the market for a new susspension set up. See what others think and use.
Sat May 04, 2013 10:49 am
the old skool thought was bilsteins and 6 cylinder -35mm H&R springs
Sat May 04, 2013 1:07 pm
How many miles on the dampers that are on the car now? 100,000 mile dampers don't necessarily need 'uprating' - they just need renewing.
DasChin
Sat May 04, 2013 2:08 pm
118k miles. Don't see point in renewing 25 yr old shocks. Update or just get new standard.
Kos
Sat May 04, 2013 2:17 pm
You can't go wrong with bilstein eibach or H&R combined in any format
It's an upgrade / modification that's good for any e30
www.pukardesigns.com
IG Pukar.Designs
billgatese30
Sat May 04, 2013 2:18 pm
I think that is what Brian meant, Das. I.e. replace like for like with new OE dampers, rather than 'upgrade' to aftermarket spec/manufacturer, rather than some kind of refurbishment.
DasChin
Sat May 04, 2013 9:06 pm
Ah ok. Replace the current with OEM.
anothere21323i
Sat May 04, 2013 9:13 pm
I used B6s and eibach springs and ARBs on mine and loved that combination. I've no experience of H&R stuff but I'm sure it's equally as good. Why not try new OEM stuff?
DasChin
Sun May 05, 2013 7:32 am
I will look into it. been offered the b8 set up with KW springs for good money so worth a punt.
