anyone run the Bilstein B8 sports kit?
they look good and been offered a set to try out. currently m3 is on std shocks and lowered springs. feels a bit floaty.
thanks, DC
uprating e30 m3 suspension....
ajay
Im using B8 dampers with a H&R spring kit and think there great, no floaty business: quite firm but not harsh. Would be my first choice if i was in the market for a new susspension set up. See what others think and use.
the old skool thought was bilsteins and 6 cylinder -35mm H&R springs
How many miles on the dampers that are on the car now? 100,000 mile dampers don't necessarily need 'uprating' - they just need renewing.
DasChin
118k miles. Don't see point in renewing 25 yr old shocks. Update or just get new standard.
Kos
You can't go wrong with bilstein eibach or H&R combined in any format
It's an upgrade / modification that's good for any e30
billgatese30
I think that is what Brian meant, Das. I.e. replace like for like with new OE dampers, rather than 'upgrade' to aftermarket spec/manufacturer, rather than some kind of refurbishment.
DasChin
Ah ok. Replace the current with OEM.
anothere21323i
I used B6s and eibach springs and ARBs on mine and loved that combination. I've no experience of H&R stuff but I'm sure it's equally as good. Why not try new OEM stuff?
DasChin
I will look into it. been offered the b8 set up with KW springs for good money so worth a punt.
