What lowering springs or ...
Davebmx
Looking to lower my girlfriends car a little bit but not sure what to buy, saw that different cars have different strut sizes what would i need to lower this any help would be great thanks.
Rtaylor2208
Going on the picture it looks like you have a 4dr Saloon. Most importantly is what engine does it have?
Chris_B86
It's a 316 so presume 45mm struts. Initially you could do it with just a set of springs, which will be OK upto 40mm, anymore I'd suggest springs and dampers. Just make sure you buy the springs for a 4 cylinder, if you buy 6 cylinder ones, they are sprung differently to compensate for extra weight, so you'd probably end up highr than when you started
1990 E30 325i Sport Sterling Silber
1999 E36 323i Sport Touring Techno Violet
Rtaylor2208
As chris says above you need to make sure you use the springs that suit the weight of the engine so something from a 316 or 318.
Also make sure they are from either a 2 or 4 door saloon as cabs and tourings use different rear springs due to the extra weight.
Genuine Mtech Springs give you a -15mm drop over standard, all the aftermarket ones depend on the manufacturer.
