What lowering springs or ...
Davebmx
Post Sat Apr 20, 2013 7:52 pm
Looking to lower my girlfriends car a little bit but not sure what to buy, saw that different cars have different strut sizes what would i need to lower this any help would be great thanks.
Rtaylor2208
Post Mon Apr 22, 2013 9:57 am
Going on the picture it looks like you have a 4dr Saloon. Most importantly is what engine does it have?
Chris_B86
Post Mon Apr 22, 2013 10:16 am
It's a 316 so presume 45mm struts. Initially you could do it with just a set of springs, which will be OK upto 40mm, anymore I'd suggest springs and dampers. Just make sure you buy the springs for a 4 cylinder, if you buy 6 cylinder ones, they are sprung differently to compensate for extra weight, so you'd probably end up highr than when you started
Rtaylor2208
Post Mon Apr 22, 2013 11:18 am
As chris says above you need to make sure you use the springs that suit the weight of the engine so something from a 316 or 318.
Also make sure they are from either a 2 or 4 door saloon as cabs and tourings use different rear springs due to the extra weight.
Genuine Mtech Springs give you a -15mm drop over standard, all the aftermarket ones depend on the manufacturer.
