When I turn the heating on to setting 4 it makes a loud vibrating noise. When on setting 1-3 there is a very quiet squeaking noise.
Not much air seems to be blowing through but car is still getting heat coming through.
What is the most likely cause?
Heater motor making loud noise
ThomasBellamy
Cheers, I had a look at this first and assumed that this may be the cause. I will have this out tonight and clean and lube to see if it makes a difference.
Tom
Tom
ThomasBellamy
I think I'll take the motor out and do it and wipe any excess before refitting!
ThomasBellamy
Popped the motor out to find that a few of the blades have come loose which is causing the loud noise. Can the fan parts be detached and replaced or do you have to buy a whole new heater motor unit.
Also, the fan spins on settings 1-2 and 4 but not 3... does this mean I need a new resistor pack?
