Wiper spray nozzle upgrade...?
Gavla
Post Tue Apr 09, 2013 7:07 pm
As above, is there an upgrade or do I just need to get a new pump?
Gavla
Post Tue Apr 09, 2013 9:10 pm
The washer fluid kind of trickles onto the windscreen rather than sprays.
Post Tue Apr 09, 2013 9:59 pm
get a pin and clean the washer jets,you can aim the direction again when they are cleaned out as your bound to move the nozzles when doing this.
Andy325i
Post Tue Apr 09, 2013 10:15 pm
Keep meaning to see if the citroen xsara ones fit in the E30 bonnet holes. They give a lot better spray pattern :)
Gavla
Post Wed Apr 10, 2013 12:33 am
Yes holes cleaned and nozzles pointing in the right direction, I will check the valve tomorrow, thanks.
Post Wed Apr 10, 2013 9:15 am
if the none return valve is broke it will leak,i've used these before ....
http://www.ebay.co.uk/itm/Washer-Tube-C ... 4606ead054
cheaper than bmw and work fine .does the washer pump buzz when you press wash ?
hongkongfuey
Mad-tango-geezer
Post Wed Apr 10, 2013 10:29 am
check the washer hoses are not crushed or folded
with cars like mine,
Grrrmachine
E30 Zone Wiki / Team Member
Post Wed Apr 10, 2013 12:37 pm
hongkongfuey wrote:check the washer hoses are not crushed or folded
This is the most likely scenario, followed by a failing pump. Nozzles would be the last thing I'd check.
FinalD
Post Wed Apr 10, 2013 1:13 pm
Andy325i wrote:Keep meaning to see if the citroen xsara ones fit in the E30 bonnet holes. They give a lot better spray pattern :)
I want to get hold of some Ford or Citroen mist type as that seem like a better idea and I don't need to sit there for hours with a pin directing. Also seems like a sensible idea with the cab as it'll mean I don't cover myself in a jet of fluid ever. :D
ross_jsy
Post Wed Apr 10, 2013 2:05 pm
I want to get the type that some French turds use that spray from the wipers. Will be useful as my bonnet is on pins
Post Wed Apr 10, 2013 2:39 pm
pipes aren't going to suddenly crush themselves and you know if the pump isn't working by lack of a buzz coming from it .
out of all the e30's i've had [over 25] if the washers didn't work it's been down to the none return valve leaking and my own washer jets have glogged up more than once .
just speaking from experience :D
ross_jsy
Post Thu Apr 11, 2013 12:22 am
Speaking as an ex mechanic, probably 50% of cars in for a service spray better once you have poked a pin down and blown out the spray nozzle (was one of the steps of a service) so I would definitely check it first, followed by the return valve.
Morat
Post Thu Apr 11, 2013 9:12 am
Are the return valves meant to relieve pressure if the nozzles are blocked? Mine seem to have small holes drilled in them which fire water at the bulkhead unless I keep the nozzles really clean....
Post Thu Apr 11, 2013 10:47 am
Morat wrote:Are the return valves meant to relieve pressure if the nozzles are blocked? Mine seem to have small holes drilled in them which fire water at the bulkhead unless I keep the nozzles really clean....
i think you need a new one Miles ,this is what happened to mine even with clear jets,those holes are there for a reason so you could be right .
those ebay ones are value for money
Morat
Post Thu Apr 11, 2013 11:26 am
Another one for the list :/
ross_jsy
Post Thu Apr 11, 2013 12:40 pm
I had done in the past and have done it on friends beach race cars but the spray gives better coverage
