i swapped my wind screen over the weekend, bought a tool from ebay to put the trim back in, well worth the money . swapped in about 15 mins
here is the item
http://www.ebay.co.uk/itm/121080653582? ... 1497.l2649
windscreen
hongkongfuey
- Mad-tango-geezer
with cars like mine,
ross_jsy
Really useful bits of kit. I have used a bent coat hanger in the past
clipper
10cm wide plasterer's knife. Prised mine in relatively quickly with that. Tricky at the corners though...
Trouble with the two methods above is one slip in the wrong direction, and the A pillars, scuttle or roof need repainting. Once you've used the correct tool, especially one with a roller, you won't want to do it any other way.
Duke137
Got a pic or link of the tool used Brian?Brianmoooore wrote:Trouble with the two methods above is one slip in the wrong direction, and the A pillars, scuttle or roof need repainting. Once you've used the correct tool, especially one with a roller, you won't want to do it any other way.
hongkongfuey
- Mad-tango-geezer
The tool I bought and used has a roller. Check the link I put it has pics.
