windscreen
hongkongfuey
Mad-tango-geezer
Post Mon Apr 08, 2013 6:06 pm
i swapped my wind screen over the weekend, bought a tool from ebay to put the trim back in, well worth the money . swapped in about 15 mins
here is the item
http://www.ebay.co.uk/itm/121080653582? ... 1497.l2649
with cars like mine,
ross_jsy
Post Mon Apr 08, 2013 6:43 pm
Really useful bits of kit. I have used a bent coat hanger in the past
clipper
Post Mon Apr 08, 2013 9:57 pm
10cm wide plasterer's knife. Prised mine in relatively quickly with that. Tricky at the corners though...
Post Mon Apr 08, 2013 11:37 pm
Trouble with the two methods above is one slip in the wrong direction, and the A pillars, scuttle or roof need repainting. Once you've used the correct tool, especially one with a roller, you won't want to do it any other way.
Duke137
Post Mon Apr 08, 2013 11:38 pm
Brianmoooore wrote:Trouble with the two methods above is one slip in the wrong direction, and the A pillars, scuttle or roof need repainting. Once you've used the correct tool, especially one with a roller, you won't want to do it any other way.
Got a pic or link of the tool used Brian?
hongkongfuey
Mad-tango-geezer
Post Tue Apr 09, 2013 9:18 am
The tool I bought and used has a roller. Check the link I put it has pics.
