Hi,
The TC2 is going back on the road this week, the only MOT issue was a bulging brake hose and a bit of exhaust fart
Time to sort out the niggles including the heater valve....leaking and poor heat...replacing the stereo as thed cassette has died and I cant listen to Now 6 anymore. One of the leather seats needs redying and the car needs a service.
An annoying and Baur specific problem is that the rear window demister motor isnt working. I dont know if this is a part found on non baur cabriolets. The TC2 has a blower motor and electric heater under the rear parcel shelf to blow hot air onto the plastic window. My one isnt working.
If anyone has any experience of a similar problem and any common faults I would be very grateful for suggestions before I take the shelf to bits.
Baur TC2 rear window blower motor
baur320
The blower is a unique Baur part. I did't realise there was a heater under the rear shelf - mine only had a blower which blew cold air.
Current E30 325i, E63 630is.
baurscoot
Thanks - any ideas which fuse it runs off?
The ' heater' I have on mine looks suspiciously like the heater element of a 12V hairdryer!
looks like someone has modified it!
Given the location of the motor it is in a prime position for getting clogged up with dust etc. Suspect if it is't dodgey wiring it will be caked in fluff
baur320
Sorry Scoot, car's gone so can't remember which fuse the fan runs off, but would be suprised if it's heated for the risk of the window becoming damaged.
This is the only thing I can find out about the fan:-
http://bmwfans.info/parts/catalog/E30/2 ... briolet-4/
The fan itself (part 3) is apparently still available.
Baurtje
The fuse is the same as on the heated rearwindow.
Gr Jeroen
Gr Jeroen
www.Baur-TC.de
BMW 318i 2d '85 Cosmosblau
BMW 325iX Baur TC B47095 '87 Alpinweiss
BMW 325iX Baur TC B47172 '87 Zinnoberred
BMW 320i High Executive 4d '07 Monocablau
Rtaylor2208
Does the fan look the same as this:
http://www.ebay.co.uk/itm/BMW-E30-3-SER ... 0707424138
If so its the same as a cabby one. Mine would not blow hot air and it turned out to be the relay on the fan had corroded terminals. A clean up with contact cleaner and some wet and dry made it an easy fix.
