Rear disk brake shield plates
verde
Post Tue Mar 05, 2013 7:43 pm
Does anybody have a set to sell or can they be bought from bmw. Mine are rather roosty so i need a new set while the arse end is being swapped out
I can find pictures of what im after but dont know where i can get some
Raise hell praise Dale.
maxfield
Post Tue Mar 05, 2013 7:52 pm
Sure they're still available from BMW dude.
cjdonny
Post Tue Mar 05, 2013 7:53 pm
i got mine from here not bad price
http://www.bmminiparts.com/PriceFinder.aspx
318 IS
tomislav
Post Tue Mar 05, 2013 7:57 pm
Am i right in thinking that you have to pull the wheel bearing apart to fit them tho?
sunnyr83
Bmw still do them for £30 each iirc.
cjdonny
Post Tue Mar 05, 2013 8:00 pm
318 IS
Craggy73
Post Tue Mar 05, 2013 8:37 pm
Rear Left (34211162061) & Right (34211162062). £26.60 each
Just about to order a pair myself
Post Tue Mar 05, 2013 8:59 pm
tomislav wrote:Am i right in thinking that you have to pull the wheel bearing apart to fit them tho?
Cut in the narrowest place with a 1mm cutting disc, twist into place, bolt them up, and run a bead of weld along the cut, avoiding where the handbrake shoe lies.
verde
Post Tue Mar 05, 2013 9:38 pm
Craggy73 wrote:Rear Left (34211162061) & Right (34211162062). £26.60 each
Good god, that will need to wait a moment or two then. Thanks guys, next month il get some. Just bought a 600D. These can wait
Post Tue Mar 05, 2013 10:05 pm
600d ?
billgatese30
Post Tue Mar 05, 2013 10:31 pm
magpie wrote:600d ?
One of these at a guess
CLICK
Stonkin
Post Tue Mar 05, 2013 10:39 pm
I just bought a rear pair last week from bmw, they were about £20 each but i get a 10% discount. Bit of a pain to change but not too bad :)
Chris_B86
Post Tue Mar 05, 2013 11:39 pm
Just fitted mine. £26 each from the stealers. Make sure you order new bearings too
1990 E30 325i Sport Sterling Silber
1999 E36 323i Sport Touring Techno Violet
polsta
Post Wed Mar 06, 2013 7:54 am
Chris_B86 wrote:Just fitted mine. £26 each from the stealers. Make sure you order new bearings too
how long does it take to do all in ? how much are the bearings ? when the pin went through the rusted hole on my old is it was a bit of a mission to bodge fix it with washers, have no idea what the current ones are like
cjdonny
Post Wed Mar 06, 2013 8:01 am
Just buy a new fixing kit(annti rattle screws) when you get the plates and bearings
318 IS
Craggy73
Post Wed Mar 06, 2013 8:24 am
polsta wrote:...how much are the bearings ? ...
Think the stealer ones are over £50 each, someone may know better. I've got some ebay specials for £20 each. They say they are made in Germany by 'HANS PRIES/TOPRAN' so will see how long it is before my wheels fall off...
Chris_B86
Post Wed Mar 06, 2013 9:00 am
I got the bearings from GSF, £20 each. It's not a quick job, I took the trailing arms off, and then took them to a friends to have the hubs and bearings pressed in and out
capnmchl
Post Wed Mar 06, 2013 10:03 am
Think CP4L do SKF bearings, which probably would of been OEM, for around £25 a side.
verde
Post Wed Mar 06, 2013 10:08 am
If correct magpie said one of the rear arms already had new bearings so id only need one side, still, thats going to be around 100 quid, i was expecting maybe 25 in total and a relatively easy swap. bollocks
Chris_B86
Post Wed Mar 06, 2013 10:12 am
verde wrote:If correct magpie said one of the rear arms already had new bearings so id only need one side, still, thats going to be around 100 quid, i was expecting maybe 25 in total and a relatively easy swap. bollocks
New it may be, but you will not pull the hub without the inner race of the bearing splitting and coming with it
Chris_B86
Post Wed Mar 06, 2013 10:15 am
There is a pikey way to do it, you could cut the back plate and put it on with some jiggery pokery without pulling the hub and tack it back up
verde
Post Wed Mar 06, 2013 10:18 am
Fuck it, it can wait. My dads exact words were " just dont do too many handbrake turns and itl be fine "
Its a bit shaky and probably wouldnt handle a days drift abuse, but im not a drifter so itl be fine for now. Il sort it out nearer summer
Chris_B86
Post Wed Mar 06, 2013 10:26 am
verde wrote:**** it, it can wait. My dads exact words were " just dont do too many handbrake turns and itl be fine "
Haha what a guy. I've never once used a handbrake to initiate a drift, clutch kick like a boss! haha
polsta
Post Wed Mar 06, 2013 10:38 am
does sound like a ball ache- 2x plates £50 + bearings £50 + fixing kit screws, plus all the time/labour to do it, il give mine a good inspection when i do the suspension , being a 1986 car they must of been done at some point hopefully
Chris_B86
Post Wed Mar 06, 2013 10:49 am
polsta wrote:does sound like a ball ache- 2x plates £50 + bearings £50 + fixing kit screws, plus all the time/labour to do it, il give mine a good inspection when i do the suspension , being a 1986 car they must of been done at some point hopefully
Only reason I've done it is the car is off the road so I've had time and I've replaced everything back there, bushes, bearings, brakes, cables, back plates etc
Couple of pics at the bottom of this thread...
http://www.e30zone.net/modules.php?name ... c&t=234146
Craggy73
Post Wed Mar 06, 2013 11:07 am
Chris_B86 wrote: Only reason I've done it is the car is off the road so I've had time and I've replaced everything back there, bushes, bearings, brakes, cables, back plates etc
I'm doing exactly the same and collecting all the parts ready for a full strip down at the back. You could just cut off the rust plates for now, will make your car lighter and faster :mad:
Chris_B86
Post Wed Mar 06, 2013 11:24 am
He could, but then his brake shoes would fall out haha
Jozi
Post Wed Mar 06, 2013 11:30 am
Brian posted up these little spring retention hats that you could use if the sping had pulled the screw through the backplate, makes no sense what I just said but Brian will know if he reads this :D
Chris_B86
Post Wed Mar 06, 2013 11:32 am
I know what you mean, it's basically a washer with a slit and groove to hold the locking pin in on the back
Jozi
Post Wed Mar 06, 2013 11:49 am
Chris_B86 wrote:I know what you mean, it's basically a washer with a slit and groove to hold the locking pin in on the back
Yeah pretty much, I can't remember their name or find them on ebay.
Post Wed Mar 06, 2013 2:03 pm
Craggy73
Post Wed Mar 06, 2013 7:12 pm
Arh, I see. I've got discs on the back.
Grrrmachine
E30 Zone Wiki / Team Member
Post Wed Mar 06, 2013 7:33 pm
You've still got a handbrake, and that uses shoes
