Speaker recommendations please!
Drumzii
Fri Mar 01, 2013 11:12 am
Hey folks!
I figure its about time I upgraded my speakers on my E30 cabby.
What speakers do you guys use? I'd like high clarity and speakers that have a decent bass and mid.
Looking to spend about £100 or so I guess?
Cheers peeps!
Chris_B86
Fri Mar 01, 2013 12:18 pm
Problem with the E30 is you can only fit a 5.25 inch speaker in the original place, which it's hard to get decent mid from, unless you start chopping door cards to put 6.5 inch in.
I've currently got Focal 5.25 inch in the front, and I've put the mids from a 6.5 inch Hertz Dieci component system in the back shelf for a bit of extra mid, and it sounds pretty good.
If you're looking at new ones, look at Focal, Hertz, JL Audio
Focal you'll get Access within budget
Hertz Dieci you can get for about £60
JL Audio you should get C2's within budget
Just remember it's all in the installation, I've heard £500 systems wipe the floor with £2000 systems just because it's been installed better
1990 E30 325i Sport Sterling Silber
1999 E36 323i Sport Touring Techno Violet
Kos
Fri Mar 01, 2013 12:53 pm
I'd also consider infinity and some of the alpine range
However if you want a but more bass look at the vibes. Not that musical and the tweeters can be harsh but they have a decent power rating and can be amped up with good results and will provide some much needed bass. But their magnets are quite deep so fitting in the original location may require a small spacer
www.pukardesigns.com
IG Pukar.Designs
jas025
Fri Mar 01, 2013 7:47 pm
Had infinity in the back but they didn't have the clearance and pushed out the standard rear covers with the tweeter dome as well. Went for Alpines in the end, £30 rears powered off the head unit from halfords and Alpine component fronts (£80) powered from the original pioneer GM-620 amp. Good enough for me - the amp in the front lifts it nicely and there's no clearance issues.
Thehouseshuffle
Mon Mar 11, 2013 7:50 pm
I fitted 5.25 hertz, sound deadening is a must with some dynamat on rear panels
http://www.e30zone.net/modules.php?name ... c&t=234179
polsta
Fri Mar 15, 2013 8:34 am
think im going focal this time round, what are they like compared with hertz ?
had vibe slick 50s x4 in my old is , they were good for the money but want something a bit better this time
