Fri Mar 01, 2013 12:18 pm
Problem with the E30 is you can only fit a 5.25 inch speaker in the original place, which it's hard to get decent mid from, unless you start chopping door cards to put 6.5 inch in.
I've currently got Focal 5.25 inch in the front, and I've put the mids from a 6.5 inch Hertz Dieci component system in the back shelf for a bit of extra mid, and it sounds pretty good.
If you're looking at new ones, look at Focal, Hertz, JL Audio
Focal you'll get Access within budget
Hertz Dieci you can get for about £60
JL Audio you should get C2's within budget
Just remember it's all in the installation, I've heard £500 systems wipe the floor with £2000 systems just because it's been installed better
