E30 differential and exhaust hanging?
E30REDD
Post Sat Feb 23, 2013 11:36 pm
Is this something critical or should the hanging look like that?
I've also got a question regarding the exhaust hanger. I bet this is not how it is supposed to hang. How should I hang it the proper way?
Post Sat Feb 23, 2013 11:47 pm
the diff bush looks fine,it's got void spaces for movement comfort .
2nd pic is an after market silencer bodge 8O
E30REDD
Post Sat Feb 23, 2013 11:52 pm
magpie wrote:the diff bush looks fine,it's got void spaces for movement comfort .
Okay, is it something very bad with an after market silencer bodge? :p
Silverfang
Post Sun Feb 24, 2013 12:08 am
I take it the hanger is the one on the sub frame. (Big bar going across the width of the car just in front of the Differential)
Looks like the pipe isn't even aftermarket, just someone's bodged it completely :eek:
Should be a hanger on the pipe and a rubber there that looks like a number 8.
BMW and Opel, both RWD, both german, both good fun
http://www.clockservicing.co.uk/ For any clock repairs try here.
Post Sun Feb 24, 2013 10:10 am
The hanger on the standard pipe quite commonly breaks loose, taking a section of the wall of the pipe with it, especially if efforts aren't made by the exhaust fitter to balance the loads taken by the various hangers. Any sign of a patch welded on the pipe?
The missing piece is essentially a length of 10mm round steel bar welded along the pipe then bent to shape to meet the rubber mount.
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Feb 24, 2013 10:51 am
If you look at this exhaust pipe:
http://allegro.pl/tlumik-koncowy-bmw-31 ... 59258.html
You can see the mounting arm welded on the side. This is supposed to hook onto the rubber mount you have on your car. As Brian says, it probably broke off and someone has made a very cheap repair.
E30REDD
Post Mon Feb 25, 2013 7:40 pm
Okay, is it okay to drive with the exhast like I do?
It's knocking when I'm driving on small pits.
E30REDD
Post Mon Feb 25, 2013 7:41 pm
Brianmoooore wrote:The hanger on the standard pipe quite commonly breaks loose, taking a section of the wall of the pipe with it, especially if efforts aren't made by the exhaust fitter to balance the loads taken by the various hangers. Any sign of a patch welded on the pipe?
Yeah, I can see that someone have welded a pipe before the cat.
