Wipers go all the way to the bottom of the screen and come up and stop ! , i used to be able to tap the stalk down a little a a time and get them to sit at the bottom of the screen ,
Is the motor buggered or is there a solution.
Thanks James
No, they would behave as they should. Push the wipers down to the bottom of the screen by hand when the arm is off (very slightly lower that where you want them, to allow for lash in the linkage), and push it back on the motor shaft.BATTS91 wrote:That is where they stop ,but the wipers do swoop to the bottom of screen then come back up and stop .
So if i were to do that the wiper would scrape down the scuttle .
