Wheel stud conversion
Bristol_Jer
Post Sun Dec 30, 2012 6:13 pm
Anyone used these?:
http://www.ebay.co.uk/itm/Stud-conversi ... 29f9a77c59
Saw them on ebay and wondered if anyone had tried them and what the quality is like?
BATTS91
Post Sun Dec 30, 2012 6:30 pm
not used these but id opt for press in studs over these .
Bristol_Jer
Post Sun Dec 30, 2012 7:20 pm
That would mean removing the wheel hub and pressing in from behind wouldn't it? Don't want to take the hubs off really as I've only just fitted a new pair of front wheel bearings
harry_p
Post Sun Dec 30, 2012 9:40 pm
I've never heard of anyone using press in studs in an e30, mainly because it would be a massive ballache as you'd have to get the hubs machines to accept a splined stud.
There are loads of people using screw in studs, I'm sure there have been threads in the Motorsport / trackdays section.
As long as the studs are a decent grade, and thread locked in place then they'll be fine.
cheers,
harry
penton08
Post Sun Dec 30, 2012 9:42 pm
I use similar screw in studs on my track car, my wheels have not fallen off yet :D
Post Sun Dec 30, 2012 9:48 pm
I can appreciate the advantage for a track car, especially if running endurance races, but what's the point on a road car?
There's a perfectly good tool in the boot tool kit to line a wheel up to the holes in the hubs.
Post Sun Dec 30, 2012 10:18 pm
I have a set of these I used for about 2 trackdays, £30 posted if you want them? Bought from the same ebay seller.
I changed to longer shouldered studs with bullet noses for quicker swapping of wheels.
Nothing wrong with the quality, just make sure you clean the hub threads out with a tap and brake cleaner before loctiting them in 8)
Bristol_Jer
Post Mon Dec 31, 2012 12:16 am
Thanks for the replies :)
DanThe wrote:I have a set of these I used for about 2 trackdays, £30 posted if you want them? Bought from the same ebay seller.
PM'd :thumb:
