ive been driving the car without a temp gauge for a while now and i really need to sort it, basically i had a look at the temperature sensor for the e30 and for the m52 , the e30 one has 2 wires coming from it, but the m52 has 4? , how can i wire my e30 gauge up so i dont have to fit aftermarket one,
any help would be appreciated
e30 temp gauge to read m52 engine temp...
rich318i
the 4 pin is for the engine temp to the ECU (blue sensor) the 2 pin is for the gauge (brown sensor)
you need the 4 pin hooked up or the ECU will think the engine is stone cold all the time and will be over fueling big time
i could be wrong as it was sometime ago i did mine
eko
- Old timer
You need to find the brown/violet wire in the 4 pin plug and snip it then run that wire to an e30brown sensor screwed in next to the 4 pin one.
daymo69er
thanks eko!!!! i understand ill pick up a new brown sensor and see what happens! , you from plymouth by any chance matE?
