ABS Warning Light
MrH
Post Sat Dec 08, 2012 1:58 pm
Just had to jump start the old girl - was sitting for 3 weeks. The ABS warning light is now on. Its a 1988 model. Definately wasn't a warning light prior to jump starting.
All other electrics seem OK and no other warning lights.
Ideas? - failed relay someplace - blown fuse somewhere? Its a 1987 model car.
Thanks is advance
Post Sat Dec 08, 2012 2:14 pm
IIRC jump starting can blow the ABS relay - possibly the silver one thats clipped in place above the glovebox.
Post Sat Dec 08, 2012 2:19 pm
Using jump leads on modern cars should be avoided! Your ABS ECU is protected against voltage spikes by the over voltage protection relay, as mentioned above, and it will have sacrificed its life doing its job.
Morat
Post Sat Dec 08, 2012 4:24 pm
I think you might be pushing the definition of modern there, Brian :wink:
mcbonio
Post Sat Dec 08, 2012 4:31 pm
It could also be low battery voltage... when a battery is near flat first thing that comes on is ABS light IIRC..
MrH
Post Sat Dec 08, 2012 5:05 pm
Thanks guys - a new relay will be purchased!
