When I get the car into the garage, sometimes when going the ramp down on corner slowly you can hear and feel on the entire car like knocks.
Don´t know if it´s the same thing but when riding over potholes with the right rear Wheel you can hear a big clunking noise like something is loose.
At the moment we have done so far:
-new rear shock absorbers and rubber mounts 25000km ago
-new right output shaft (had been without grease with cracked rubber boot too much time)
-diff seems to have no play (with car lifted up when you turn the Wheel front/back the input shaft moves without play) and all upper screws are well tighted
-diff bushing has no cracks and it´s entire
-rear axle and struts bushings are ok. Tried to move the axle and struts with a crowbar and no play was found.
The car starts to be scary and don't know what is happening here
