Stuck/rounded bolts and turbo sockets
Coops90
Alright chaps,
Not an E30 problem, but probably relevant.
Got a horribly stuck, and now rounded bolt whilst trying to change the front springs on my Mums mk6 fiesta. Ring spanner rounded it a bit and stilsons wont even make it budge. its now pretty much circular.
Found out about these turbo socket things which look to be my last resort. Has anyone used them?
And it may sound daft, but if its a 15mm bolt head, will I need a 15mm turbo socket because its so rounded?
Cheers,
Pete
Cheers,
Pete
maggspower
- Turbo Farmer Tractor Driver
What part of the suspension is it?
Coops90
Its the bolt holding the strut to the hub
Malachite uber alles
maxfield
Had that exact problem once but someone had been in before me fitting lowering springs.
I used an irwin easy out kit that I bought from machine mart.
Lurch320i
ive had this problem on plenty of fords around that age, since rounding or snapping a few i've just left the hub attached to the strut and just removed bottom ball joint, drive shaft and track rod end.Remove whole assembly and change the springs with the hub still attached
Coops90
This is the little shite
Coops90
Thanks for the tips chaps.
Going to try the lower ball joint again tomorrow, that bolt wont budge either!
I'll look into the easy out things too.
Lurch320i
IIRC then its a nut and bolt with a torx head on it. T40 possibly, but I always remove the 13mm nut and tap the bolt through
Also got to remove the caliper obviously, good luck though
Coops90
Yeah its the torx one. Got the nut off but the bolts going nowhere. Fucking fords.
Lurch320i
swear at it? offer to take it to dinner?
only messing
grab a half inch extension and a hammer and give it a bit of persuasion,
only messing
gas axe and warm it up a little
Lurch320i
you'd end up setting fire to the ball joint gaiter or driveshaft boot if you werent VERY careful
dubownerbilco
Get a bolt splitter on it and break the bugger off, never failed for me
maf260
Irwin easy out should shift that. I have the full set and they've been a life saver many times.
Other option is to weld another nut to the rounded bolt head. The heat of the weld often breaks any corrosion and you have a fresh nut to grip to - use an easy out with this as well for extra shifting capacity.
