eta identity
dazleeds
old skool raver
old skool raver
Post Sun Nov 27, 2005 11:00 am
hi all
might be buying a 525e in the next couple of days
but the owner is convinced its a 2.5??
how can i check if tis 2.5 or 2.7??
car was an import and logbook also says 2.5 but
its a very clean car and has to be worth checking out #
cheers all
Daz
www.oldskoolfantasy.co.uk
Widge
Post Sun Nov 27, 2005 11:08 am
Does the log book also say "525e"?
Dunno about casting or engine numbers, I would say the only sure fire way is to stick a stick down the bores. Try a bit of wire down the spark plug hole on your's before you go to look at it and mark off - ah you don't have a 2.5 do you?
E30Mark
wow a rare 252e !!!
plant your foot on the load pedal and see where the rev limiter is, i beleive the 325e cuts out around 4.5K
have you got the chassis number?
PM for details
Widge
Post Sun Nov 27, 2005 11:12 am
Yeah the rare 2 series with the even rarer 5.2 ltr straight 6! Built for economy not speed!
dazleeds
old skool raver
old skool raver
Post Sun Nov 27, 2005 11:14 am
Dohhh edited lol
not got chas no
but owner has checked and it came back as a 525e but says 2.5 again
so im a bit confused
all 525e,s had a 2.7 didnt they??
ps widge
no 2.5s here mate :cry:
Martinaston
Post Sun Nov 27, 2005 11:27 am
Does it not say 2.7 on the side of the block casing in raised letters ?
The log book should say 2700 or there abouts.
There is NO nucleus.
dazleeds
old skool raver
old skool raver
Post Sun Nov 27, 2005 11:39 am
not been to see it yet mate
just hunting for all the tell tale signs before i go
owner doesnt seem to know either way for sure
as car was imported some years ago
and the original docs no longer available
Templ8e30
Post Sun Nov 27, 2005 11:51 am
Hi Daz, the 525e eta engine has the block stamped with 27 6E B on the same part of the block as the engine number : Image
And also on the side of the head between number 4 and 5 cylinder it will have 2.7 ETA cast onto the head like this : Image
Hope this helps you out mate,
Iain T
2007 Mazda 6 2.0 estate
dazleeds
old skool raver
old skool raver
Post Sun Nov 27, 2005 12:12 pm
nice one Iain
will email now and get him to check for me
cheers fella
Daz
Widge
Post Sun Nov 27, 2005 12:16 pm
Daz what is planet E30?
dazleeds
old skool raver
old skool raver
Post Sun Nov 27, 2005 12:21 pm
pm,d ya widge
rayman
Post Sun Nov 27, 2005 1:02 pm
All eta,s in this country were auto,s {swichable box}
