hi all
might be buying a 525e in the next couple of days
but the owner is convinced its a 2.5??
how can i check if tis 2.5 or 2.7??
car was an import and logbook also says 2.5 but
its a very clean car and has to be worth checking out #
cheers all
Daz
eta identity
dazleeds
- old skool raver
www.oldskoolfantasy.co.uk
Widge
Does the log book also say "525e"?
Dunno about casting or engine numbers, I would say the only sure fire way is to stick a stick down the bores. Try a bit of wire down the spark plug hole on your's before you go to look at it and mark off - ah you don't have a 2.5 do you?
E30Mark
wow a rare 252e !!!
plant your foot on the load pedal and see where the rev limiter is, i beleive the 325e cuts out around 4.5K
have you got the chassis number?
PM for details
PM for details
Widge
Yeah the rare 2 series with the even rarer 5.2 ltr straight 6! Built for economy not speed!
dazleeds
- old skool raver
Dohhh edited lol
not got chas no
but owner has checked and it came back as a 525e but says 2.5 again
so im a bit confused
all 525e,s had a 2.7 didnt they??
ps widge
no 2.5s here mate
not got chas no
ps widge
no 2.5s here mate
Martinaston
Does it not say 2.7 on the side of the block casing in raised letters ?
The log book should say 2700 or there abouts.
There is NO nucleus.
dazleeds
- old skool raver
not been to see it yet mate
just hunting for all the tell tale signs before i go
owner doesnt seem to know either way for sure
as car was imported some years ago
and the original docs no longer available
Templ8e30
Hi Daz, the 525e eta engine has the block stamped with 27 6E B on the same part of the block as the engine number :
And also on the side of the head between number 4 and 5 cylinder it will have 2.7 ETA cast onto the head like this :
Hope this helps you out mate,
Iain T
Iain T
2007 Mazda 6 2.0 estate
dazleeds
- old skool raver
nice one Iain
will email now and get him to check for me
cheers fella
Daz
cheers fella
Daz
Widge
Daz what is planet E30?
dazleeds
- old skool raver
pm,d ya widge
rayman
All eta,s in this country were auto,s {swichable box}
