Hi great site I am in the process of buying a m tech 1 325i sport
It has a problem with regards to as soon as it is started the temprature guage rises to the red instantly .Even if the car is cold . I have asked a few people and the culprit seems to be the temp sensor or maybe a bad earth behind the clocks . Has anyone come across this problem before . Also the car runs fine no oil and water mixing .Heaters are warm and water is circulating around the engine properly any help would be helpfull thanks raz
Newbie temprature problems
capnmchl
Sounds like somethings shorting to earth. Shouldn't be an expensive problem.
E30machine
Thanks bud hope it's a easy fix think I'm going to rule out the head gasket and concentrate on the temp switch and bad earth theory
Grrrmachine
- E30 Zone Wiki / Team Member
First thing to do is to disconnect the 20 pin C101 engine loom plug and socket next to the fusebox, turn the ignition on, and see what the gauge does.
E30machine
Thanks guys lets just hope I can get it sorted for when collect the car on saturday
Morat
I hope you have checked up her skirts and given her a firm prodding!
E30machine
The guides on here have got me all clued up
Loads if usefull info . I'm giving it a thorough inspection when I go to collect it on Saturday fingers crossed shes a good un .will get some pics up when it's back home can't wait been after a tech 1 for years
