tia Mick.
rev counter no worky
the rev counter on my black 320i has stopped working,what's the easy fix procedure here
tia Mick.
tia Mick.
+ a yard full of scrap turds
Rev. counter can quit when the batteries on NiCd battery equipped SI boards begin to fail, and the signal from the ECU seems to be sensitive to a poor connection on its way to the cluster, so check that the C101 engine loom plug is fully engaged in to its socket, with the lock ring turned as far as it goes.
will have a look in the morning and let you know ,the service lights are on so i'll see if they reset then we'll know if the si board is good or duff .
BenHar
and ?BenHar wrote:Posts: 19935
BenHar
Thought you might have read some as well.magpie wrote:and ?BenHar wrote:Posts: 19935
Brian answers this one weekly.
Also thought you might know about the technical section.
Ben
verde
Fuse 21
either that or speedo plug may be loose
Raise hell praise Dale.
Kedge
BenHar wrote:Thought you might have read some as well.magpie wrote:and ?BenHar wrote:Posts: 19935
Ben
OOOH soooo sorry:roll: why would i read about a rev counter not working last week when mine works fine but the car i've just bought doesn't.Kedge wrote:BenHar wrote:Thought you might have read some as well.magpie wrote: and ?
Ben
post whore spammer!
thanks for your patience Brian
BenHar
Moi?magpie wrote:
post whore spammer!
Ben
fuse 21 is the winner ,nice one Verde looks like you have a use on here after all
thanks Brian your tips are noted should i dare need to ask in the wrong section again .
sorted
sorted
verde
magpie wrote:fuse 21 is the winner ,nice one Verde looks like you have a use on here after all![]()
sorted
If you'd told me that the interior lights, boot light and clock/OBC didn't work as well, I would have told you to check fuse 27. Since you didn't, I assumed they were working, hence the problem could not be fuse 27. I can't see your car, and can only work on info. given.
If that info. is wrong or incomplete, then so will be the diagnosis!
A blown fuse is NOT a fault - it's a symptom of a fault. Now you'll have to find why it blew. Start with the boot light wiring on the hinge, and the glovebox light (if the car's pre mid '88).
i've not noticed the interior/dash lights not working because i've not driven or worked on it in the dark .
but still it's fixed now and i gained a wee bit more knowledge if just the rev counter should fail
BenHar
It's not really fixed.
You've just put fixing it off for a while.
As Brian says, fuses blow for a reason.
Ben
Ben
i'm breaking the car,now the clocks are fully working i can sell them as such
BenHar
Thug.magpie wrote:i'm breaking the car,now the clocks are fully working i can sell them as such
Ben
i just bought a diamond tipped blade for the stihl saw
BenHar
If you need any help ftting the blade, post the question in "Other Marques".magpie wrote:i just bought a diamond tipped blade for the stihl saw
Ben
don't you have anything better to do ben nothing you have to say is constructive ,the clocks are fixed so do one
BenHar
Touchy aren't you. Sorry if I'm interfering with your business.magpie wrote:don't you have anything better to do ben nothing you have to say is constructive ,the clocks are fixed so do one
This is the chat section. If you want sensible talk go somewhere else.
Ben
why do you feel the need to keep posting on my thread more shit ,is that what you've been eating because it stinks .
i asked a question it got answered and the part is now fixed if you can't be happy with that maybe you should go somewhere else and while your at it check you crotch for red stains
BenHar
Very touchy.magpie wrote:why do you feel the need to keep posting on my thread more shit ,is that what you've been eating because it stinks .
Is it the time of the month?
Ben
polsta
This is. Bit rich coming from someone who follows me around on here like a possessed stalker always trying to have a dig
