early style ignition barrel
mark_i
Post Wed Nov 14, 2012 8:34 am
anyone know how to remove an early style ignition barrel?
1985 chromie, no hole is present to insert a thin nail.
mark_i
Post Wed Nov 14, 2012 7:18 pm
VIN is wbaae62030101031384
Jim320i
E30 Zone News / COTM Team
Post Wed Nov 14, 2012 7:27 pm
Have you removed the plastic surround? With the earlier type there is a push like button on the side that needs pushing in once you turn the key although it isnt visable until the plastic column surround is removed
mark_i
Post Wed Nov 14, 2012 7:36 pm
Cheers... dare i say Thanks for Fixing It Jim :mad:
Jim320i
Post Wed Nov 14, 2012 7:44 pm
:twisted:
Just for you to cross reference, this is the type im refering too...
http://www.ebay.co.uk/itm/281023321776? ... 1555.l2649
mark_i
Post Fri Nov 16, 2012 5:29 am
turns out that the alloy casting around the steering column has a 2mm hole for inserting an allen key or thin nail with the key on position 1...lock popped out like a good 'un once the steering wheel and lower shroud were off.
Jim320i
Post Fri Nov 16, 2012 9:30 am
That's what I said :) push button... Loads easier than the later type too
Rorym2010
Post Mon Nov 19, 2012 10:35 pm
sorry to hijack your post but how do u remove the ignition barrel on a 92 touring it has a small hole under the key slot but i cant get it to turn when the keys in?
mrrodney
Post Mon Nov 19, 2012 11:25 pm
does the key turn?,.
mark_i
Post Mon Nov 19, 2012 11:45 pm
oooh... the small block in the ignition barrell can only be pushed in when the key is turned to position 1... if the key cant be turned, then you'll have to sacrifice the barrel, or do a complete column/bracket swap.
btw wiggling the steering wheel while turning the key may release the lock to allow you to get into position1
Jim320i
Post Mon Nov 19, 2012 11:48 pm
Have you sprayed it with wd40?
Try that first... If not, and it turns to the first position, you can use a pin nail to slide down into the hole and it pushes and releases the barrel, you'll have to pull on it too from memory
This will help you
http://www.e30zone.net/e30zonewiki/inde ... ition_Lock
