Refitting prop....
flick-it
Is it possible to refit your prob with engine and box still bolted in position? If so how? Thanks
maxfield
Yes it is. Should slide shorter on the splines.
gmf_uk
i take it that its unbolted from the diff ??
No need to slide it shorter on the splines to remove it. Dropping the centre bearing down is all that's required.
flick-it
Cheers sorted it
I needed to remove heat shield and drop center bearing. Thanks
Did you pre load the centre bearing when you refitted it?
