Is it ok to run different profiles on the front and rear
I am going to run 205/45 and 215/40 8.5j at the rear for a staggered set of bbs rs
Tyre profile size
ETERNITY
325i sport tech 2, lach silver, 1989, BBS RS 16 split rims,
[URL=http://s878.photobucket.com/user/ETERNI ... 0.jpg.html][img]http://i878.photobucket.com/albums/ab35 ... 46cc30.jpg[/img
perfectly fine,all you need is a matching sized pair per Axel.
+ a yard full of scrap turds
Need to have similar rolling radii front and back if you have ABS.
HairyScreech
^^ The abs thing is quite important, otherwise it will be constantly thinking the rear is locking, not a good start.
However otherwise its fine.
ETERNITY
So will my fronts need to be 40 as well
I do have abs
I will just run with 45 fronts and 40 for on rears for now.
It brakes fine
I do have abs
It brakes fine
ETERNITY
I am running staggered bbs rs
7.5 j and 8.5J and tyre place has put me 205/45/16 on the front and 215/40/16 on back
Should I get these replaced ASAP or should I replace asap
Will It be ok for doing a motorway trip tmoz
HairyScreech
225/40/16 would be a closer match. (0.8%)
your currently at 2.1% difference.
Hopefully someone with more experience of staggered wheels on an e30 will be able to say better.
ETERNITY
225/40 would catch the arch, with 215 it's totally clear.
Seems to drive better with 215/40 than 225/45
I think most staggered set ups run differant tyres.
HairyScreech
Yeah, a lot of people on here are running those sizes, one should be along soon.
verde
Im running a healthy suspension drop and 9" wide allround on 215/40s and i have no arch catching issues what so everETERNITY wrote:225/40 would catch the arch, with 215 it's totally clear.
Raise hell praise Dale.
ETERNITY
225 can cause arch issues if the et is high
