c/l probs .
Post Fri Aug 03, 2012 10:02 pm
i turned my alarm off and the doors and boot unlocked,now i think at this stage the c/l relay has failed as nothing locks from the alarm but the alarm still arms up.Now i can't lock any of the doors or boot because the car appears to be deadlocked open if that makes any sense :?
how do i lock the car now :(
Barx325i
Post Fri Aug 03, 2012 10:07 pm
deadlocked open? that's a neat trick :)
have you done the red wire in the drivers door loom? Mine worked ok, then intermittently failed & the red wire had completly corroded in the multipin nylon plug - this came about shortly after a speaker fitment, so it gave me clue. soldered up and has been peachy ever since
baggimodo
Post Sat Aug 04, 2012 7:02 am
I've got a C/L relay knocking about magpie! I bought the one off you, then found one in my spare wheel well :mad:
Post Sat Aug 04, 2012 8:04 am
yeah just my luck i sold my last one then i need one myself most probably :mad:
i'll have a look at the bugger on sunday as today i'm converting a 320i into m20 b25 pooowah! :D
baggimodo
Post Sat Aug 04, 2012 8:30 am
Wish me luck, I'm swapping my M40B18 out today! :D
Post Sat Aug 04, 2012 8:26 pm
how did it go ^ and what did you swap it with ?
baggimodo
Post Sat Aug 04, 2012 8:40 pm
Swapping like for like mate, have got the old one out, will probably have to wait till next weekend to fit the replacement as I need a water pipe (plastic part on below the inlet manifold)
It's been an experience, if nothing else! :mad:
Pacerpete's was an auto so the difference in the flywheel assembly is puzzling me a little. Once the clutch is removed would I just swap the flywheel onto the replacement? :?:
Post Sat Aug 04, 2012 8:51 pm
i have loads of m40 hoses here including that plastic one you need :)
Pacerpete's was an auto so the difference in the flywheel assembly is puzzling me a little. Once the clutch is removed would I just swap the flywheel onto the replacement? Question
yes indeed ^ but use locktight or threadlock on the flywheel bolts when you put them back in :wink:
baggimodo
Post Sat Aug 04, 2012 8:58 pm
Interested in a trade for a C/L relay? PMSL!
Ah thanks mate, was getting a little worried about that!
Post Sat Aug 04, 2012 9:44 pm
Plus add a spigot bearing, or the gearbox will have short life!
Post Mon Aug 06, 2012 8:09 am
baggimodo wrote:Interested in a trade for a C/L relay? PMSL!
if you test the relay in the boot by plugging it in to your car ands it works i'll swap ya for the plastic pipe winkeye
