Ecu swap wont start
jimmymig
Post Wed Aug 01, 2012 4:30 pm
Got a suspect ecu that iv tried to swap with 2 working ecu's car wont fire ! Anyone had this before thought they were interchangabel
Post Wed Aug 01, 2012 4:38 pm
Which ECUs are you trying - they should have a part number on, e.g. 0 261 200 405.
Post Wed Aug 01, 2012 4:52 pm
If the car has the EWS system then you need to also make sure that the new ECU also has the corresponding EWS box and the key.
e30-EVN
Post Wed Aug 01, 2012 5:16 pm
^this.
M52 ecu's are not interchangable unles ews gear that coresponds to the new Ecu is used.
M50 ecu's are interchangable though
Post Wed Aug 01, 2012 5:25 pm
Don't the later vanos M50's have EWS too, or was it just the M52?
rich318i
Post Wed Aug 01, 2012 6:21 pm
you can pay to get someone out to code it all up for you but thats £120 for 20mins of work
Post Wed Aug 01, 2012 6:23 pm
Or you can get DanThe to delete the ews
Post Wed Aug 01, 2012 8:10 pm
E30BeemerLad wrote:Don't the later vanos M50's have EWS too, or was it just the M52?
Maroon label M50 ECU = No EWS.
Silver label M50 ECU = EWS.
They are directly interchangeable.
Post Wed Aug 01, 2012 9:32 pm
E30BeemerLad wrote:Or you can get DanThe to delete the ews
Cheaper than coding :)
jimmymig
Post Sat Aug 04, 2012 1:17 am
Cheers lads will pm dan :D
