Ecu swap wont start
jimmymig
Got a suspect ecu that iv tried to swap with 2 working ecu's car wont fire ! Anyone had this before thought they were interchangabel
Which ECUs are you trying - they should have a part number on, e.g. 0 261 200 405.
If the car has the EWS system then you need to also make sure that the new ECU also has the corresponding EWS box and the key.
e30-EVN
^this.
M52 ecu's are not interchangable unles ews gear that coresponds to the new Ecu is used.
M50 ecu's are interchangable though
Don't the later vanos M50's have EWS too, or was it just the M52?
rich318i
you can pay to get someone out to code it all up for you but thats £120 for 20mins of work
Or you can get DanThe to delete the ews
Maroon label M50 ECU = No EWS.E30BeemerLad wrote:Don't the later vanos M50's have EWS too, or was it just the M52?
Silver label M50 ECU = EWS.
They are directly interchangeable.
Cheaper than codingE30BeemerLad wrote:Or you can get DanThe to delete the ews
jimmymig
Cheers lads will pm dan
