busted timing belt????????????????
E30Spaz
has anyone here busted their timing belt? if so is it true that the valves will bend? what is the chance of the valves being okay?from what i have heard they always bend
can any one help me with this pondering thought?
dasparkybad
I work for a bmw specialist and have never seen a busted timing belt that did not bend at least one valve but thats not to say it is not possible the only way to find out is to fit a new one and try and turn the engine (spark plugs removed) go slowly if you have any resistance to turning it you probably have a bent valve do not try to force it past this point if so as you will do further damage ! if not and the engine turns freely do a compression test to make shure all the valves are sealing
good luck
good luck
tylerma
my cam belt went about 2 months ago
when i took the head off it had hit and bent 1 valve
touring170
my mates 318i g reg m40 engine teeth came off the belt and it was ok never seen that b4 must b blessed by angels ?
