busted timing belt????????????????
E30Spaz
Post Sat Nov 19, 2005 1:18 pm
has anyone here busted their timing belt? if so is it true that the valves will bend? what is the chance of the valves being okay?from what i have heard they always bend :cry: can any one help me with this pondering thought?
dasparkybad
Post Sun Nov 20, 2005 10:02 am
I work for a bmw specialist and have never seen a busted timing belt that did not bend at least one valve but thats not to say it is not possible the only way to find out is to fit a new one and try and turn the engine (spark plugs removed) go slowly if you have any resistance to turning it you probably have a bent valve do not try to force it past this point if so as you will do further damage ! if not and the engine turns freely do a compression test to make shure all the valves are sealing
good luck
tylerma
Post Sun Nov 20, 2005 10:56 am
my cam belt went about 2 months ago
when i took the head off it had hit and bent 1 valve
touring170
Post Sun Nov 20, 2005 2:37 pm
my mates 318i g reg m40 engine teeth came off the belt and it was ok never seen that b4 must b blessed by angels ? winkeye
